Mp5t
Status
Not open for further replies.
So I just got about 20 diferent AN4 Fittings and 20 Feet of Stainles Hose.
The Fittings are sitting in Lye, which is an acid that will remove the Red and Blue coating.
I will probably have the Vac Hoses run by Saturday afternoon.
did that with all my fittings earlier this week. thanks for the tip it worked great
The Photo called OCD is the turbo Oil Return to the Engine. It is a Full AN10 Stainless line that drops 90 Degrees into a 45 Degree fitting into the windage tray. Rather than putting this into the oil pan below the oil line, this return is placed deliberately above the oil level so it will function properly. If I were to be asked to choose one picture that describes the level of detail that I put into my build, it is this picture.
this is awesome!!! It's builds like this that motivate me to want to build my motor. Keep up the great work. Looking forward to future progress.
UPDATE: I managed to get the AN16 Fittings on to the Braided lines.
Sorry for the s*** picture, and yes there is a blanking plate missing where the hose meets the head. It is being welded Thursday..
No the hose will not touch the intake, It's a bad angle..
I usually don't ask about financial things but do you keep record of how much you have spent on the car? Top notch work as usual.
D'oh I didn't even look at that. That's a lot of money. I don't even want to know how much he's spent on labor and how much he's saved on labor by doing everything by himself. Crazy.
The cost would be triple if I paid someone to do it and it would be a third as well built
Yes it is but if you have the money and a passion, go for it...which is what Brian is doing and everytime I see new pics, I tip my hat to him. The attention to detail from top to bottom and end to end is superb!
Status
