The sedan has them on the fenders not the p5...
His ticket not mine
03 P5's have them on the fender also
Diff stroke's for diff folk's you dont like it keep it moving.... Looks good OP
His ticket not mine
The sedan has them on the fenders not the p5... And all cars have to have a visible turn signal on the side, the front signal light you can't see from the side and neither is the rear.
His ticket not mine
It is a reflector...
It is there for safety...
Painting it will simply get you into s*** with the cops...
I don't say s*** just to be an asshole...
mine dont work because of previous asshole owner.
drop that s*** homie...the wheels look sweet!
Are you running spacers w/ extended studs or did you modify the STI wheels?? because IIRC the STI wheels have a 56.1mm center bore compared to Mazdas 67.1mm. If you just slapped them on that is not the safest idea in the world.
Hi,
I'm new to this forums and I had a question for you. I to was planning to put on gold sti rims on my 03 pro5. What do I need o do to make it fit?
ex:
bore out the hub?
get spacers?
get longer lug nuts? special kind?
Thank you for your time.
David
