The good thing is, he has a TON of equity in it. Trade in would be around $18,000, and he only owes $8,000. His wish list might be a hard sell though...he would want something brand new, or at the very least, something with less than 15,000mi, but only wants to be around the low $20,000's. It also would have to be something "cool", something manual, fast, V8 or forced induction, etc. No soccer mom SUV's or run of the mill sedans. lol
The mileage might be hard to come by, but he can get a late-model Mustang GT or probably a Challenger R/T for a V8. He might want to consider something like an Infiniti G35/37 or a 350Z if he's open to imports. Those are just a few that come to mind. I'm sure I can come up with a laundry list of ideas.
I didn't get a new control arm or anything I was just trying to take it apart to replace the spring. I got the bolt about the inch of the way out and it stopped moving and eventually wouldn't turn. Of course, I forced the issue and after a couple loud snaps it spins all day now but it won't go back in or out and bits of the rubber pushing are coming out with every rotation of the bolt.
I'll try and snap some pictures of the specific situation I have if necessary.
I am green with envy that the bottom of your car is in that condition...
In the words of Peaches, "Cut it...". Can you cut the head of the bolt off and just replace it with a new bolt/nut? Or is the other side of the bolt threaded into a welded nut? I don't know Miata's. I'm sure Phen or aMaff will come in with all their wisdom soon.![]()
that's not the miata, it's the speed 3. If I remember correctly, there is no nut at the other end, and it won't be easy to cut the head off..... I never had issues with mine, in your situation I might try to force it out with an air hammer or something. You'll need a new bolt, probably a new control arm as well since the threads will be shot. Have you tried to shock freeze it?
Good luck with the fix, Will. I hope its simple. Let me know if you need anything to help you get it figured out.
WillD, I actually Towed the car home a few hours ago so I think I'm going to ask around and see if someone wants to part with their seat indefinitely. Thanks though!
That... sucks. Sounds like you broke the internal nut that it threads into off from its welds. Happens a lot of places fairly commonly, including Miata rear control arms at the bolt for the bottom of the knuckle and some Honda subframes.
There is very likely an access hole in the subframe where you can get a wrench on that nut. You may need to dremmel yourself a notch to give yourself enough room to get a wrench in there. Good luck.
/insert snide remark about trailblazer SS vs jeep SRT8 debate from paaaaaages ago here lolPHP:
I didn't get a chance to look into that website linked but a manual SS would be sweet...
What do you mean by shock freeze?
I started finding a few of each of those as well. Couple Mustang GT's w/under 10K for a little over $20K, and quite a few Infinity/Nissans. The NISMO 350's are pretty sick looking!
You didn't miss much, just a website on how to swap a 6speed AUTO. Not sure how that was relevant to talks of swapping a MANUAL, but apparently Wes thought so. lol
