bikingpro5
- 03 Protege5
Well since i posted a few pics in a few other spots guess ill post a few here to show a bit more of whats been going on this winter in the garage.
received a box and this was in it.
i was bored so decided to polish it a bit so that it looks a bit better in the engine bay
testing to see if the cast aluminum would polish to my standards
since im adding boost to a auto-rans a larger trans cooler was needed
first time it was mounted to make sure the plate worked and to check clearance and mark the holes that needed to be cut for the IC
cut the crash bar so that the IC fits in the lower grill opening better
test fitting the header clearances with the SC
test fitting the bumper to make sure the IC sits where i wanted them to sit
