See if the small ground connector for the AC compressor is hooked up, it's the single black wire that runs off the engine harness over the PS pump and down to the AC comp. Otherwise yeah it's probably a loose connection, bad relay or bad fuse. If you have removed the panel recently make sure you hooked up both of the cables that run behind the dash, I realized the other day I forgot to hook up the driver's side cable for who knows how long.
Also maybe try refilling the system, sometimes they act up when they are low on Freon. I fill mine with the R134a cans from the parts store.
the thing is, I havent touched under the engine since installing the FMIC and it has worked fine since then, until now
i can't remember man. it's been so long since i've driven mine. lol. I THINK it's the one under the hood. but i could be wrong. it's a 50/50 shot.
A 50/50 chance... Think about that for a minute... If I said to you, "You've got a 50/50 chance you'll win the lottery." Your response would be something like, "Hell yeah, lets play!" If I were to say, "You've got a 50/50 chance you'll die during the surgery." You'd probably be like, "**** that, I'll take my chances." LOL
Good thing were just talking about a 50/50 chance I'll have to check more than one place then :p Not as dangerous sounding.
AWR's arrived! I've got to go to class tonight after work, so the install will have to wait until tomorrow!
Uploaded with ImageShack.us
Make sure you contact Tony at AWR. He's really good at making things right if there is ever a problem.
