hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
does the a/c light turn on?
I had that problem with my 02 P5, but my MSP luckily has never done it.
See if the small ground connector for the AC compressor is hooked up, it's the single black wire that runs off the engine harness over the PS pump and down to the AC comp. Otherwise yeah it's probably a loose connection, bad relay or bad fuse. If you have removed the panel recently make sure you hooked up both of the cables that run behind the dash, I realized the other day I forgot to hook up the driver's side cable for who knows how long.
Also maybe try refilling the system, sometimes they act up when they are low on Freon. I fill mine with the R134a cans from the parts store.
check the fuse?
check the fuse?
(werd)
Is the fuse in the fuse panel in the footwell or under the hood?
i can't remember man. it's been so long since i've driven mine. lol. I THINK it's the one under the hood. but i could be wrong. it's a 50/50 shot.I'm at work lol...car is in the parking garage.
Ass. LOL
the thing is, I havent touched under the engine since installing the FMIC and it has worked fine since then, until now
That sucks. I've always heard good things about the AWR's. I'm also going to purchase an AWR oil pan.I think my awr front mount might be broken ugh.
I've replaced 3, maybe 4, oe front mounts in 20,000 miles.Well it lasted longer than the stock one for sure.. on twice the hps.
