Is the painter reasonable on price?
projects coming along man!!
ford ignitions do the same thing also. i had to replace an ignition in my old fullsize bronco. was the exact same process. just push the little button, and the whole thing pops out. ford then even cut my key to match my doors for me.
Steering columns > You......![]()
I think he told Wes $300 or so, but honestly, I find that kind of hard to believe. Once the truck is ready to go, I want Wes to call him and make sure they're both on the same page as far as what needs done, so there are no surprises.
Pretty much every ignition i've done is like that in some way, even on these newer cars.
i know on the older 80's/90's mazda's they were bolted to the steering column with two bolts that had a rounded domed head. ive had to remove them before. and had to cut it with a dremel making a slit, then used a big flat head screw driver.
That doesn't seem bad. I think I will get the body work done on my P5 and find a way to do the paint work myself. It turns out I had my rose colored glasses on and didn't see all the dents on the passengers side, the scratches I saw but not the dents. Sorry for the thread jack Wes.He said 300 for paint and 300 for labor, but that's with the truck coming in basically totally prepped and already masked off.
Fabbing custom seat brackets is more time consuming than I anticipated... (spin)
custom rear bumper by tor. will hold a 40 easily. they even proved it to me :kiki: its alot nicer than these bad pics turned out. simple and strong. maybe a lil too strong for a bumper :lol:
