Wagonbacker9
- 2004 'Hoe
Yes the car was running as perfect as the stock tune can be. AFRS are normal, the car won't even go into boost unless I ease on the gas so it's hard to get a reading. I guess I have to buy another cable, seems like I should be able to make this one work if it worked before. The CEL thrown meant the MAF voltage was too high so it's a problem with the MAF signal.
Well, the tuners express job is to manipulate the MAF signal being shown to the ECU, so if I were you, I would flash a tune of strait "10"s into the tuner. This should then effectively be doing nothing... and if you still have a problem, then you'll at least be able to narrow it down. Until you get there, you're going to chase your tail. If that clears your issue, then you can move on to the superstock map, and then start working out your AFRs from there.
