So NGK long reach plugs would warrant the same results?
i wouldnt run them without the washers, if you look at the diameter of the hemi plug its a lot narrower, i dont think it will seat well and clearance wise the plug will sit deeperI cant get the crush washers off my plugs, just thought they would thread off but thats not the case. Will I be safe to run them without the washers or do they give the plug just the right clearance?
you must use the washers from your existing plugs. they wont just pull off either. you must "unscrew" them off. clean the threads and use some plyers (gently) to unscrew them.
and hurry and install these! lol I want to see what your impression is about these plugs. lol
please do! If anyone else is interested in trying these out I have a set of 4 for cheap!I will be installing a set in the next couple of days. I will update ASAP with my pics and impressions.
please do! If anyone else is interested in trying these out I have a set of 4 for cheap!![]()
