PrinceValorum
- 95 626 FS, 89 Toyota Derux 4x4
I dunno, simpler to wire up for turbo setup? I'd rather have less computers. Why do the Honda guys swap from obd2>1?
Anyone else get some Yuengling on draft today?!
saw this on thechive and laughed, had to post figured some of you guys would get a laugh at it too (its from the YSU student paper hahaha)
I may be from Ohio, but I have a 100mph ass and a below avg size at 100mph is still a lot of penis.
so, I didn't drive yesterday since I was home sick. Today as I was getting to work, I noticed the parking brake light was on, I made sure the brake was off, if I pull it the light gets brighter... I touched the rear rotors when I got to work, they weren't hot...
^^^this Happened to me once before as well and for me, I needed new pads.
Check your brake fluid reservoir. Every Mazda I've had will show that light if it's low. And when the weather cools down and that fluid becomes more dense, the level often dips down below where the sensor will read.
Check to make sure that the float on the cap is actually seated right. I had an issue with the one on the Bavaria. Even tho it was in there, the float was pinched and wouldn't move... telling me the fluid was low.
That will cause the fluid level to be low too. But considering that the weather has, at least where I am (not in e-hio), gotten a lot cooler in the last week or so, that's where I'd start.
Yep, I got that. Having low pads will cause the pistons to have to move more, which will cause the fluid to be lower. So, low fluid, in your case, was a symptom of the pads. But I think we're arguing the same side here at this point hahaUnderstood, I was just saying that in my instance I needed to replace the pads.
I guess Mazda started consolidating their warning lights in the '90's. My RX-7 has warning lights specifically for low brake fluid, low coolant level, and get this, low washer fluid level!!Check your brake fluid reservoir. Every Mazda I've had will show that light if it's low. And when the weather cools down and that fluid becomes more dense, the level often dips down below where the sensor will read.
