Dude this swap is easy then! LOL
Thank you for the answers with no smart ass responses. I truly appreciate it!
Of course, I'll help out as much as possible, man. (2thumbs) But I hope that was sarcasm with the "easy" comment. haha
Hey Lewis - you went with aftermarket mounts I saw. But - think I could get away with just solid filling the mounts from the FS, and use those with the KL? Or would that produce some nasty vibrations?
Think those axles from my ATX 2.0 will work with the ATX 2.5?
If you've ever tried to replace your rear motor mount you'll know you'll want to upgrade it with the motor out. But I understand money is tight. And I'm not positive on your axles for the ATX, but I wouldn't see why they wouldn't work. Try double checking part numbers with Mazda, they might have the same part numbers as the MTX axles. Sorry I can't help more right now, I'm at work...
The KL vibrates muuuuch less than the FS. Solid poly mounts are no big deal.
Don't forget about the electrics.![]()
Yeah, my KL has AWR front and rear mounts and AWR side inserts and it doesn't vibe much at all, even with the lightweight parts on the motor. But I would still rather invest in some low duro new mounts while you have easy access to all of them. But that's just me. And if anyone is doing a KL swap consider a bigger front sway while you have easy access to it too.
