Wes and I ran to Pull-a-Part yesterday and I picked up a shift linkage from Probe GT. He and I cleaned it up a bit and painted it to prevent rust then I slapped it on. The shifter is nice and centered again, yay! It's much easier to shift with it in it's normal location again.
HUGE thanks to Forzwin for doing the research and measuring on that for us! Then I changed my tranny fluid with Redline 75w-90. I just used some Valvoline for the break-in period for the transmission. Probably wasn't necessary but I wanted to be safe than sorry. But god I hate the smell of tranny fluid...
Then I installed the Sparco steering wheel. The center was chrome so I scuffed it up and painted it black. I rented a steering wheel puller from Autozone and popped off the P5 wheel, airbag and clock spring so I could mount the new hub and wheel. I don't think I can get it perfectly straight because the teeth are off on the steering shaft but it's pretty close. It's still gonna drive my OCD crazy though. heh-heh. Oh, and I now know what the clock spring does. So now I have to cancel my turn signals manually. No biggie though.
Today I installed the Unorthodox underdrive pulley and new belts. Since I already prepped the blocks aluminum fins, it only took about 30mins to swap them out. I read tons and tons of reviews on ProbeTalk.com and it seems like it's a 50/50 like/dislike on there. But then again, a lot of PT is just "well, my friend said this about _____ product...". I'm more into first hand experience. If you haven't seen the part in person then shut up. I love PT.com but damn there are a lot of newbs on there with bad information. Hell, I'm a newb but at least I don't run around saying s*** that isn't fact or based on real world experience. And I'm done with that rant, forgive me. Anyway, as I posted earlier, Josh welded the screws in the backin plate for me so they aint goin no wheres, yO! A lot of cats buy eBay pulleys, the screws come out and they b****. Well then don't buy cheap s*** and cry when it breaks. Oy. Anyway, so far so good with the Unorthodox pulley. I reset the ECU and let it idle about 5mins (which is still even at 700rpm) and ran down the street to McD's for a samich and soda with a WOT pull into 4th. Everything ran well and no surprises. Though I did stall it in the drivethrough line. haha! But that tells ya there is a difference in rotational mass. Or maybe I just stalled because I don't know how to drive. Regardless, I'll keep a close eye on my electrical devices and headlights to see if there is any problems with charging. Oh, I also noticed I didn't tighten the 10mm bolt holding my crank position sensor in place. It was loose. That would've sucked. Haha
Side by side comparison. I should've weighed them. The UR pulley is SO much lighter.
Here's a decent pic for future reference if anyone does get a pulley for their KL. These are the aluminum and plastic fins you need to shave down with a Dremel.
And I washed the dog and mowed the lawn. So I'm done for the day. It's freaking hot. heh-heh
