- '13 CWP MS3 & '16 Mazda6 GT
Haaaaaaaaaaaaaaaaaaaaaaaaar!
Who needs A/C? I've NEVER touched mine.
Apparently everyone in Northeast U.S. does. LOL!
It would be a shame if you did Nate. You have one of the nicest MSP's I've seen...
Does anyone here run their damn AC??????? I NEED to be able to use it? Is that not going to happen with a FMIC?
Thanks Ivan, I"m gonna take atleast a month before I decide. Maybe she'll change my mind.
ya once you fix the coolant overflow tank it might be a little better, but either way, try draining your coolant and then flushing it with a bunch of water to get any junk that is sitting in there, no need for distilled water really, just flush it with the hose I would think should be fine, or just buy a few gallons of water at the store, after that go with a 70:30 coolant (I think that is the limit is says on the bottles) but if not then 60:40 with coolant to water ratio so it will increase the boiling temp. after that.. well besides not using the A/C, which at least for the last week, up north here has been the same temp as down there after checking the weather lol, been about 90-100 for the last week but anyways get the 2 12" slim fans, and wire them so they both come on at the same time, as I explained in the FMIC thread... if they had 13" fans I would have gotten those, because the 14" won't fit I'm pretty sure, but 12" fits great, and the stock fans won't fit either, MAYBE for the A/C fan, but it's not worth it, you'll just dig out a hole into either the hot pipe or the fan eventually.. for an extra $50 or so, you can buy the 2 12" fans, and then just sell the ones you have..I am also replacing my overflow tank with the weapon R one since my stocker leaks.
I was thinking that could have been the reason for the heat and boiling coolant, but that doesnt solve the AC issue...thats obviously a flow issue.
well the hood dampers are on, easy 10 minute install. Atleast something can go right.
dam i thought u were talkin to me, im ivan as well. NVM!
nybody know if only the FCC ID # KPU41704 fobs are compatible with the msp's? or are the FCC ID: KPU41846 & FCC ID: KPU 41794 ok as well?
I dont lol. My AC Doesnt blow cold air. IDK why might be the FMIC issue dont know. But I always have my windows down even durning the 100+ days last week (3 days in a row 100+ haha)
