linuxology
- Mazda5_Sport
Do you rotate the tires front to back? Do you do any criscrossing of the tires? I got the original toyo's on this 5.
I see many are running 215/50/17 tires when they replace them. Does this present any rubbing issues on potholes or bumps? Thanks.
Nope. Not even close.
The OEM Proxies A18's are directional tires so you are pretty much limited to front to back "rotations" unless you get them dismounted and physically swapped on the rims!
It issomething to think about when the time comes to replace them! do you go directional or non-directional tires.
On these cars, you get more wear on the inside of the tire when it's on the back, and more wear on the outside when it's on the front. Keep your tires inflated correctly and front to back is the best way to do it. I personally wouldn't cross them unless you think the car is out of balance.
