Its super easy to remove the stock one. Disconnect the battery. Theres 2 round rubber covers on the side of the steering wheel u will need to pop off. Inside those holes, theres a bolt that will need to come out, its either a 8mm or 10mm. Disconnect the airbag and remove large nut in the center. Then just pull it off
Awesome. Sounds easy enough. Just to clarify, When you remove the two bolts on the side does it allow you to get to the airbag and the large nut in the front?
