This was Sunday am, but its my most recent mod...
Might as well...
Almost done fitting the pie cut pipe. Hopefully I have the skill to weld it together.
Thanks,
I have decided to change things up after the new year comes around. (or once the IC and exhaust are completed) Im going to be getting the car it tip top shape. lol repairing the bodywork, doing maintenance, changing bushings, endlinks, fixing my passenger side speaker. Also replacing my door cards (after i had messed them up doing the)
Well see how it goes.
thought i'd hope in here finally... a couple of weeks ago i put racing line rear end links and awr front end links, new struts and tien springs on the car then this past weekend i filled my broken front engine mount with rtv sealant (not as stiff as i'd want on my mx-3 but my car shifts amazingly now!)
Got my greddy rad cap in the mail. Also the first part of my custom exhaust. (a high flow cat. Fitted for a civic.) only cost me $26 shipped.
Hmmmm....changed the oil (only 2k overdue thanks to my recent trips to CT, OH and MA since August LOL). Also winterized her by swapping wheels and hoods. :( Since I had the hose out to clean up the summer set prior to storing them I went ahead and washed her as well as put a good coat of wax on the stock hood. The 14's look soooooo much better with the new suspension and I've decided that next spring/summer they are getting painted bronze. :) And while updating my maintenance spreadsheet I found that I've driven 6,172 miles since 8/12!!!! (drive2)
Thanks and I thought I was late for getting mine on....considering your location....you better be getting them mounted up. lol We've had no snow but I've driven a few 'early' mornings with temps near freezing and my summer tires were having none of it.
It's hard to find the time. The shop I want to get them done at closes at 17h and I'm never home around that time, so I'll prolly end up skipping a morning class to get them mounted...
mine with the new 14"s look like im going off roading! i might paint mine in a week or two a nice bright green. ill get pics up later
Oil Change, NGK spark plugs and mudflaps. the mudflaps sit too low. i scrape when i drive my car now. which is a problem that i totally forgot to fix today. so now i cant drive it till tm. wooooops
If anyone wants some steelies for their winter tires I have a set from a Mitsu you can buy cheap. I bought the winter tires on them and put them on my stockers. Let me know.
(My post sounded like a Scratch post. heh-heh.)
