mine were all blown when i put those exact sportlines in lol,
speaking of blown, i blew my head gasket yesterday. compression goes like this:
cyl
1-130
2-90
3-90
4-150
i was told it should be around 180psi all the way across? me and justanothermsp and scratchandsniff will be changeing it this upcoming saturday, the arp head studs i acquired a while back will be going in. and should i replace the cam seals and bearings? i assumed cam seals but i didnt know about the bearings
and i also got my hks flange in
how r u likin the fsze cams? did you feel a difference??
ARP Head studs get torqued down to 75 if you didnt know, I just did 20-30-45-55-60 three times, than the finial one went up to 75. More the safe it ishahaha Just if you didnt know.
its such a great lookin hood man. why get rid of it?
how much? how much? lol
You get that manifold or is it still in the post?
i couldnt remember the torque specs...lost the paper that came with mine, so thanks for the info!
is that 75 with the moly lube or oil? i could have swore it was lower then 75 ft lbs
stock is only like 19lbs or something, but arp's are 75. That is what I have mine at and that is what Sam told me that they have to be torqued down to. And yes you MUST put the lub that is supplied with them on the threads on both sides.
Someone on here said something about their ARP's being torqued to 90.... IDK why someone in the right mind would do 90 on the ARP's cause thats WAY more then what is allowed.... But whatever works for them even though its not correct.
Oh and ARP Main Studs for the crank are 45 ft/lb if you ever wanna know lol!
should of came with the ARP Studs.yeah and where can i get this said lube?
