one of the cables is disconnected most likely. air only blows to the windshield and feet
Install new front brake pads, ran the WB 02 sensor and cable into the cab, installed perrin short shifter. Now I need to check my rear pads some other day and finish my cluster pod thing.
Edit: Also greased the shifter bushings.
do you have a boost gauge?.. the wga would be a good place to start.. so would the crappy ass smic, then if you plan on modding it, go with the ssafc after that... the ssafc makes the car drive sooo much smoother (2cents).. also 85 octane.. that's terrible! lol good thing you got rid of that fast.. some people out there...(hand)
Boost gauge and WB should be in the car some time soon, an SSAFC and upgraded SMIC are probably not too far off in the future. The PO didn't know anything about the car, i'm glad it's finally in a good home.
oh, then don't bother... the cable is probably disconnected. I believe thats the one on the driver's side.
its there and connected. it reacts to every switch on the control knob. i dont really know whats wrong
make sure its not only connected but theres a sharp metal bracket thing thats holds the cable in its place as well, if the cable is loose from that teethy bracket it wont work right. the cable must be stable.
everything on my position know for my ac/heat controls are off by one. like if you go all the way to just face it still blows on face and floor. and i cant go all the way to defrost. any ideas?
^^^^the same thing is happening to me. i am trying to fix it right now
well i figured out what the problem is. that white wheel that the cable is connected to and the knob are not in sync. when the knob is all the way to the right, the wheel slector is in the second to last slot. not sure how this happened
yeah, exactly. if you move the knob at watch the other end... the post should move, the cable's outer sheath should not.
made up my mind today. the turbohoses hardpipes, intake, and adp are going to be painted with the duplicolor metalcast smoke color to give it a more stock look
The left side is the smoke and the right side is the before
(since these pieces are not chrome but polished aluminum the smoke should come out darker and more of a shiny black color)
oh i fixed it, took 2 seconds. the cable was not connected to the metal tooth. put the control knob on the farthest setting to the left (windshield), then make sure to connect the cable to the tooth.
this is the cable on the driver's side btw, get under the steering wheel and you'll see it and the white wheels its connected to
im looking on rock auto and found a bunch of wheel hubs but I'm not sure which one it is exactly.... does anyone have the part number?
Every company is going to have a different part number. Multiple manufacturers make the same parts. Competition. ;)
