why not? having it on the hot pipe means you're not wasting energy cooling air thats just going to be blown off anywaywhy BOV so far from throttle body?
actually havin on the hot pipe doesn't make a diffence.you dont waste energy either way. imo its better to have on the cold pipe since the job a bov is meant to do is to relieve pressure when throttle closes.. n it bein closer wud actually be better for its purpose
you're wasting heat transfer ability of the IC by cooling air, and then releasing it. and location relative to the TB is irrelivant (other than turbulience, in which case having it further away is better), seeing as pressure anywhere in the charge piping is the same..
stealth... you know too much about this place.
and that looks like a lot of work.
anybody got a tip on removing the hot pipe from the turbo?
Just wiggle and twist if you can... hopefully you dont have the stock plastic crap. I hear those are a pain in the ass to get off.
Driving the car around till the pipes are warmed up helps too.
Oh, I bought some DGM Parts yesterday.
Installed a few parts today on the Black MSP:
- 03.5 Lip
- G3 Brackets with H3 HID 5000K Fogs
- Projector headlights
- Hella Supertones
Fog Lights: pilot NV-602W
Turn Signals: V-led 5K HID WHITE AMBER DUAL COLOR TYPE 2 CHANGING SWITCHBACK 92 LED
I will make another run of brackets if I can sell at least 3 sets...
