Focus, is that bracket already on the car? IM to lazy to run outside and see. lol
Ya this, & also where is that? Behind/below the glove box? I need to pull out/inspect and clean up all my a/c & heater stuff (no heat or a/c, ftl) so I might as well do this, too...
Where'd you get the replacement filter? Part #?
anybody got a tip on removing the hot pipe from the turbo?
get a hair dryer and warm up where they meet for a couple of minutes. will slide off easy
stock I would assume?.. if it's stock, just get some good work gloves, run the car a little so the plastic is warmish, and pull like crazy, that's about it.. I guess spraying a little WD40 around and getting it a little lubed up couldn't hurt either, also just work the pipe back and forth (side to side kinda) as you pull it off, should come off eventually
is it me or is something missing?
but on the good side, no visable cracks
My tip: remove the end at the intercooler first. Then you have more play at the turbo end to wiggle, rock, and pull til it comes away. And yes, if its stubborn a heat gun helps.
i was able to get the heat sheild and o2 sensor off with out having to take off the pipe. I'll save that until i upgrade to fmic
now the question is: do i want to put on my steedspeed mani?
That's where I lost a bolt too. Now I think mine is gone... AGAIN. I need ot pull off the heat shield and look again, but something is leaking/missing. I need to get the bolt replacement kit and install it...
I'm just going to continue to hope my crack doesn't get worse, and all my bolts stay where they belong. I don't appear to have any leaks at this point..
Put a steedspeed mani on your registry... (lol2)
I was chasing one for a while, and had a payment ready for a couple of manifolds, (even sent on one) but got beat out... so I have been waiting for it to get worse for a couple months now and it hasn't.
I'd put a new car on the "things to do on/around wedding time" list long before I'd put protege upgrades on it. WICKED RX8 I want in houston, only 11 grand.. but... its houston, and I don't have 11 grand. lol
