I sea foamed my car and found a leak in the manifold gasket. I fixed it and sea foamed it again, now looks like its coming from my turbo inlet and outlet gasket?? Sea foamed twice to double check the leak. That turbo gaskets weren't leaking before or so may be due to the leak from the manifold which absorbed most of the leak?. Also, my car idles worst then before?? I don't know how could this happen? Too much sea foamed bad? What are the consequences of too much sea foam and can a turbo inlet and outlet gasket cause bad idling? Pls Help?
