- 03.5 YLW MSP
Just installed my prosport boost gauge and my force fed gauge pod (need to get some double side tape)
paint jobbbb
paint jobbbb
Not everybody can get a hook up
I would make them twins by appearance just one built for the dd and the other the go fast.
seriously considering taking out the medieval rear mm and putting the stocker back in. when the ac is on the dash shakes so bad it feels like the car is falling apart
I got inserts all around. Tad bit of vibration but its not that bad. I barely can tell with the music on.
down the line, will prolly do solid motor mounts on the sides and inserts on the front + rear. not tryna have all that vibration everyone keeps talkin about![]()
I might get stock with rear inserts sometime .i have an awr and its more livable now than it was, but the front mount fixed my wheel hop. i might get a stocker and engine damper.
of course, not anytime soon because its a huge PITA
vibration is an inverse function of engine movement. you either get one or the other, bottom line. what your tolerance is will determine how much you get. I've got side inserts, a 95 duro rear mount, and an epoxy filled front mount. I still get wheel hop due to what I believe are bad A-arm bushings. but my engine is rock solid. I choose not to care too much about the vibrations, and even my fiance doesn't mind them anymore.i dont care how loud the car is up there, the cabin hurts my brain lol. actually it isnt that bad since i swapped the front tires for 40s. shouldnt be that much difference in size but i guess the extra rpms needed for the smaller tire make cruising in 5th without brainsplode possible now ha.
Could always insulate the tower bar too. rubber groumets?
