My LED swap
Yeah, as mentioned before the fitment wasn't easy... but with a few tips it can be done.
Car is looks nice man.
Yeah I just put in my tower II's and they fit relatively easy.. I didn't have a problem at all and I have big hands.. They look good but aren't as bright as I thought they would be..
Never did say thanks for the write-up, so thanks! Did mine a few weeks ago, and absolutely LOVE the extra light! I get a lot of compliments about them too.
Thanks all, again I can't take full credit because I did get a lot of information from OJ Bartley. Together we just found the best alternative cost and shipping wise. I also took tones of before/after pics.
Thanks again :D.
looks good! i just did my door panels how did you take your dome lights off? I got the two screws out and then tried to pry it off but it was unsuccessful. Also what size are the ones in your hadlights? car looks good! We share the same bad ass interior!!
Get a butterknife and pry each side, they are held in big steel clips so you have to use some force but you won't break them. The manual also illustrates how to change the bulbs.
Yeah, the rear dome lights you just had to really pull on them.
As long as you take off the two screws by the sun glasses spot it's all just clips. Use a butter knife and a screw driver, it's easier when you have more then one tool and you go along the edge going for the clips.
You do need to use a lot of force, I was afraid I was going to break it with the amount of force I was using.
I would just go with the superbrightled ones.. They are not badly priced and have great output.. I'd be afraid to go with ebay ones if it was me..
I really want to do this what am i looking for on ebay what size of bulbs do I need for everything
Low Beam - H1
High Beam - H1
Fog Light - H1 (non-sport) / H3 (sport) / H11 ('06, '07)
OEM HIDs on the Speed6 - D2S
Front Parking Light - 194
Front Turn Signals - 1157 (NA)/1156 (Global)
Front Side Markers - 168 or 194 (same size, different wattage)
Interior Door Lights - 194
Interior Dome Lights - 194
Glove Box Light - 194
Vanity Mirror - 74 or 2731
Rear Brake Light - 7443
Rear Parking Light - 7443
Rear Turn Signal - 7440
Rear Back up Light - 921/906
Rear License Plate Lights - 194
Trunk light - 74 or 2731
Wagon's luggage light (trunk light) is a 30mm festoon
Source: 6Crew.com http://www.6crew.com/forum/showthread.php?t=4062
You can get the bulbs from superbrightled or www.autolumination.com
I got quite a few off Ebay, most of my car is done with it and i have only had a issue with 1 that came damaged on shipping, other then that i've been using them for a year without a issue.
Low Beam - H1
High Beam - H1
thanks (bowdown)
How the hell do you get the license plate light covers off?
Very Carefully, yet forcefully lol. I used a Flat Head screwdriver to get at it. Gently pulled out, and it gave... You kinda have to work side to side to get around the clip/notch that is holding it on.
I think the hardest part was getting the freaking bulb out. (smash)
