AP help!
Romo89
Mazdaspeed 3
so im planning on getting a COBB AP
and was wondering wat map i should run with these
modes
just wanna be safe thats all
thanks,ROmo89
AEM CAI,CS catless DP&RP,HKS BOV, CP-E turbo inlet
thanks
the stage 2 is designed for a dp setup. but i also herd you need a fuelpump b4 you can run that. if anything run stage1 93 + SF. that is if you do put 93 in your car, if not than its stage1 91 + SF. the ap will tell you what mods the certain maps support..
Try this one: Stage2+MSCAI2 91 Octane. And like onelsono said try stage1 91 if Stage2 is giving you to much trouble.
just wanted to hear peoples opinions
and experiences they have had with this device..
please keep on posting
thanks
with a tbe, pump upgrade, bpv, tip, and sri. and with a stage2 93 +sf map. my car made 303whp and 345wtq on the first pull. after the pro tune it made 315whp. and the protune was safer than the base map. ..just to give you a scenario of what you can get from a ap...
from experience i would take the bpv off. I had major fuel cut with a Turboxs catless exaust MSCAI and a HKS BOV. I was on stage2+ 93. once i put the stock bpv on i had no problems!
