Would open ended black lug nuts look good on the stock RHs? They would match my car.... The reason im asking i don't want something that stands out too much, i don't want to pay 60 bucks or more and then hate them.
I see, lug nuts are expensive but I do want good ones.
so the lugnuts i got, link a couple pages ago (orange ebay) fit great, stick out a little too much, but are light weight and look good. I can tell if they have to gon on and off alot, the orange will come off.
put on the summer wheels (RH's) and attemped but fail at putting on my gt spec stuff. Not enough time or power tools handy. Figured out my rattling from the front end was my driver's side endlink was loose at the strut. Tightened that and realizer my sway bar moves alot. The bracket on the driver's side sheared off and the sway bar is just resting the bushing and subframe? Whatever that part is. checked a couple sites and decided to go with universal greaseable bushings from energy suspension. $16 i figured i could atleast try.
Go here http://www.vividracing.com/catalog/...-28424.html?osCsid=rjvtkuij0uba4qpvsusvcr94v2 and check these out. I've had Muteki's in the past and was very happy with them. I've seen them priced over $100 so these guys are priced pretty sharp. These are sorta on the deep (long) side compared to stock (stock are about 25mm long; these are about 35mm). Personally, I like the look of more exposed lugnut but not everyone does.
So which has a better coating? Muteki's or dorman's? I like the longer style but I do not want to have to buy more because the coating failed. I do not use impacts either just normal use from rotating them.
scary...so i installed my yukib vac block last night. in the brake booster line of course. it all went great, minus the fact that i hit the one like 1/4 inch check valve in that line. ayone have a part #? it runs fine just when i go into boost, the brakes dont work right away. other than that it runs great
I put the block in mine... just made sure I left a good 3" before the check valve. no issues, AND no turkey.See that's why I didn't tap into the brake booster...I want my brakes to work.
compared to the other engine work I've done.... vac block in the brake booster was a joke:I'm sure it can be made to work, I just don't feel safe doing that.
