GI: For those who want the old school M badge
Status
Not open for further replies.
1. hectik1- 1 black 1 red rear
2. TWISFM - 1 red rear
3. bluelion - 1 black rear, 4 black centercaps
4. axelaR - 1 black rear, 5 black centercaps
5. hominemodi - 1 red rear, 1 black rear
6. mortimersnerd-1 red, 1 black, 4 red centercaps
7. Fenrir - 1 black rear, 1 black
8. meicalnissyen - 4 black centercaps
9. Wagonbacker9 - 4 Black Centercaps
10.ZoomZoom06 - 4 black centercaps, 1 black emblem
11.Raustin242 - 4 black centercaps, 1 black rear
12.machine0992003-1 black centercap,
13.Ricktalife - 4 black centercaps, 2 black emblems
14.vrspeedemon - 4 black and 4 red centercaps, 1 red, 1 black
15. gudzspeed3 - 1 black centercap, 1 black rear
16. JDMJNKY - 1 Black rear ,1 Red rear
17. controlo - 1 black front, 1 black rear, 4 black center caps.
18. kbzon01 - 2 red emblems, 4 black centercaps
19. mazdaspeed32007 - 2 black emblems
20. Jflash - 2 black emblems
21. Finalresort - 2 black emblems
22. Protege5_dude - 2 Black Emblems
23. Sinoito - 1 Red Rear
24. qwerty4550 - 4 black centercaps
25. Boonestafa - 1 black rear, 4 black centercaps
26. cholland - 1 black rear, 4 black centercaps
27. Mikelebz - 1 black rear, 1 red rear
Just so you know, the "M" only comes off on the 8.5 and up centercaps...
my 05 mazda 3 has 4 clips on the back of the centercaps, but I can't seem to get the M off, but it looks as though it CAN come off. I don't know if it's stuck or not.
If it truly can;t come off I will have to change and cancel the centercap request.
do the centercaps where the M does not come off have the 4 pins on the back?
You could try taking the wheel off and popping it out from the inside
Yes, this is according to 6Crew.com...I was looking for the removable ones and finally found a set, after a bit of searching on which ones where removable this is what I found...someone may know something different though...
YEAH found the rx8 caps!!!
posting these pics to help, and mebbe get more info
I bought a set of RX8 wheels, dunno what year all 4 caps the same. NO pins
Pulled the stockers when I had the rx8 mounted and all that
found three caps WITH pins and one oddball, the oddball is actually a sheetmetal stamping over a plastic base
I have a 07 GT
from l to r: rx8 back, ms3 back, side angle, oddballcap back, ms3 CAP APART
so, clearly they do come apart, 07 and up.
some caveats, first, there is a depression that the emblem sits down in in the cap
pushing the pins out may work, I used the corner of a 8 inch chef knife and got under the emblem and worked my way around. snaps back together no sweat
the depression may have a slight effect on the new emblem. if its a decal, then the depression will show. if its a stiff plastic badgethe adhesive will only have the periphery to adher to
I have a 07 GT
from l to r: rx8 back, ms3 back, side angle, oddballcap fr, oddballcap back
the second one is the one that I have on my 05 MZ3 and cannot take the M off
It sure looks like a two piece construction
That said, so is the sidemarker, and that comes apart best with a hammer
I only have three of them, so mebbe I will have ago at getting it apart, and post back
The clips DO come out. Just need to be patient and have a couple of different size flat head screwdrivers.
28. MGM_GT3 - 2 black rear
Status
