What about this for my 2006 5?
http://thmotorsports.com/Store/Product/ItmItem.aspx?ItemId=68819&Make=MAZDA
Wow. That looks pretty extreme. It says "2 per axle". Does that mean you need 4? $400 for a camber kits seems expensive for a mild drop... (eek2)
The bad thing is I don't even want to drop it. I'm having premature tire wear on the passenger side rear due to excessive camber. Its eating the inside of the tire.
Well, if it's stock height, you should be able to correct it via a regular alignment.
My issue is that I'm contemplating swapping in a set of MS3 springs, which would drop it about 1.5"
