Jaysanooch
- 2003.5 Msp
Okay so I really don't understand why even though I'm running the stocksupermap, I still get 10.0 when I try to hit the gas. Could somebody just take a screenshot of their settings for me so I can compare and see if I have anything screwed up?
If your telling me you hit 10 AFR's on the supermap...you either need to adjust your overpressure or your AFC is not working.
Have you succesfully connected to AFC yet? Cause no offense but your all over the place....forget tuning right now and make sure the AFC is working.
How you know this for sure is 2 things...can you connect and the second is do you see the AFC take over at the set overpressure setting? Set your overpressure to +1psi....watch your wideband...it will probably go into the 10's until 1-2psi then it should climb to about 11.5-12AFR.
Please confirm this please....no use tapping into wires etc. Just trying to help man.
