- '07 16W MS3S
Today I broke my AP. What were they thinking with that pathetic little 9-pin connector??!!
			Well my car always runs sluggish after mods that require resetting the ECU. So the "first impression" thing doesn't really work for me. Felt slow after my TMIC, my intake, my inlet . . . but im putting down 300whp so all is well.
should I reset the ECU then?
	You should reset your ecu when you install a mod that will affect your engine performance.
Disconnect the battery for 15 minutes or so, then reconnect. Drive nice for a bit (some say 50miles some say 100miles). I drive nice for 15 minutes and all seems well. Your car will be re-learning fuel trims in this time period.
Then you should be good to go! Your car will also relearn if you don't reset the ecu I believe, but resetting it gives it a fresh slate.
Installed my tails after they've been sprayed.
They look really good besides the crack in them (not visible in the photo). Here are some pictures, they are a bit dark and I'm planning to put LED tail bulbs in ASAP to increase the light diffusion. I'm leaving the 3rd brake light alone for now as well.
All pictures are taken in an overcast/glare situation. In the dark they are just about as bright as stock.
Parking lights: Fail
Brake lights at approx 75':
Random Pose:
anybody else take advantage of the nice east coast weather today and clean off some of the snow/salt grime? I drove my speed3 for the first time since christmas this past week, felt good to get her out of the garage, but man was it dirty!
also ordered some continental extremecontact all seasons to replace my drag slick stockers. Almost went with the hankook summers but couldnt resist the tread durability of the all season tires.
Took 1st in the Houston SCCA Rookie Class Auto-X!!!!
Time for some wheels/tires and RSB
Awesome! Congrats(first)
Brake lights at approx 150':
Random Pose:
	jimminey Christmas im waiting for christian bale to hp out of the driver seat!
