08SPEED3Veteran
- 08 Mazdaspeed 3 GT
I know this isnt the tuning issue forum, but this tuning issue i have deals with forced induction. So i went to IAG tuning with another member yesterday and planned on having a pro tune done by Jorge from cobb. First of let me just say that Jorge one of the smartest and coolest people i have ever had the pleasure of meeting. Unfortunately Jorge was only able to give me a mild tune due to a boost creep issue as well as a fuel pressure issue. The fuel pressure issue is an easy fix with some PTP internals, but I need some input about the boost creep. Jorge explained to me exactly how boost creep works and how the factory wastegate, since I have a catless exhaust, can not work as efficiently as my car needs. Boost creep is NOT ABLE to be tuned out. It is a mechanical fault. He told me exactly this, "without better fuel pressure and better wastegate efficiency your car is too badass for its own good" lol. SO...I need to know my options. First off im no expert when it comes to forced induction components like wastegates and actuators and all that high speed stuff hence this thread requesting knowledge. I do not want to attempt to bore a larger diameter hole for the factory wastegate. that to me is bad juju. PG makes the exhaust manifold with the external wastegate and i was wondering if that could solve the problem. OR...is it possible to change wastegates on these factory turbos? And for those of you thinking im looking to run outrageous pounds of boost on the stock turbo, im not. I know the limits and so does jorge. another member on m247 was there for his tune and put down 291 HP at 17 pounds and i was informed that with the fuel pressure fix and wastegate fixed I wouldnt be even have to worry about spiking any more than 20 pounds and making more HP safely due to having more mods. Any input on my situation would be awesome. sorry for the extensive post too lol.
