Mazda5 Wheel Fitment & Photo Guide
speaking of retarded....my brother ...Who has the Mitsubishi Mirage in my profile album asked me yesterday why I didnt amor all the tires when I put them on..........(jerkit)(stfu)
i'm suprised you put them on with all that snow on the ground!
looks great, too.
Offset is 45 and they are 19x7.5 , so i have plenty of space to put some 225/35 on it with my 2" drop. They should look like this on my Cantine :D
Venom, it looks very nice and clean! I have a quick question for you, I'm planning to add some 18 x 8 Tenzo R Black Wheels, the Offset is 45, I will bought some 225/40/18 toyo tyres, My car is with the stock suspension (not lowered) do I need to use wheels spacers or something else. Thanks in advance!
i would think at stock height, 18x8 +45 would be fine. and, a 225/40-18 is almost exactly the same diameter as the stock tire.
Go ahead with this project. And don't forget to post pics here :D
You will probably rub a little bit when fully loaded and when passing over bumps on the road, but if you wanna make sure it not rubbing, just pay someone to roll your rear fender. No big deal. OEM Coil are smoother that aftermarkets performance parts, so if you plan to drop it a bit (1" approx.) then you probably don't need to roll your fender because your coil will be stiffer.
I hope my little text help you ! Lo0o0oL
Thanks Venom, tomorow will buy the rims, the tyres will have to wait a couple of months. I really like your 5, you have good taste! Have a nice weeekend!
Thanks a lot slvmazda5. I'm trying to do things right without having too much money ;) that's a hard task for sure lol.
New Wheels
Today I bought 18 x 8 wheels for my 5. I will have to wait a couple of months to buy the tyres, here is a picture, hope you like it. (spin)
Thank you very much.. I'm planning to buy the tyres two per month, so I expect by April I will have them installed. It's my project.
Will 17" 2008 Miata rims with +55 off set fit the 5?
Not sure if this has been posted before, could not find...Does any know if 17" 2008 Miata rims with +55 offset and 205/50/17 tires will fit the 5?
Thanks,
Kevin
Thanks,
Kevin
i dont see why not. stock wheels are +52.5, and thats stock tire size.
will fit Ford Fusion wheel 40 offset?
Will the 07' oem ford fusion wheels will fit the 5? I think the offset is only 40. with tire 205/60/16. will their be any problem using this wheels? thanks
would rims with 40 mm offset ok?
Would a rim with 40 mm offset fit the mazda5?
any problem using it?
- plan to use my brother oem wheels from his FORD Fusion. he change to aftermarket rims. bolt pattern and center bore are the same. but the offset is 40mm. just want to know if this will fit? 16 x 6.5. thanks
those "Should" fit fine, as long as there isnt anything weird with the spokes. I have protege ES wheels on our 5 for winter duty, and they fit just fine. the protege rims are 16x6 +50.
40mm is a little low for offset and with higher sidewall you might rub. I would arrange a test fit for sure. The rim will stick out of the fender for sure but will depends on rim width as well.
