front mount install
Tzar177
Contributor
Do you tighten down the nut on the thru bolt when theres engine weight on the bolt or when the engine is still jacked up(no weight on bolt)?
Don't think it would make sense to tighten it without weight on it, you'll just have to re-tighten it once its down.
I found it easiest to just undo the bolts and take out the front mount without any support or lifting of the engine. It works fine and makes it easiest to put the new one in.
