Look at my mod below. I put a straight through Vibrant UltraQuiet 3 inch reso in the middle of my TurboXS race pipe. I don't know about race pipe noise alone, but with the combo of dp/rp the drone at 2500 rpm was really bad. The reso fixed this without harming flow.
What I had to do was cut the rp and remove enough of the middle of it to allow for the reso and still have the rp the exact length to match up with the dp and the CBE. This part is simple hack saw work and careful measurement. The reso will fit over the 3 inch TurboXS rp, so you can make adjustments in length and angle with temporary muffler clamps. Leave enough on each end for the reso to slip over. Once it is all aligned right, you can then take it to a muffler shop and they will spot weld, remove the clamps and then complete the welding. They will not know that this was replacing a cat. They don't know what you are connecting it to. They just have a pipe, flanges, a reso and some clamps.
Just a thought . . .
