Hi Mazda Forums,
While on a trip 500 miles form home a couple weeks ago, the Check Engine Light came on. I cleaned the battery terminals and it went off. I thought I was done, but it came on again a couple weeks later. (Evidently pulling off the negative cable for a couple minutes is how you reset that light, so be careful in your resolutions).
One common (but not so easy) "Check Engine Light" fix for this car is an ERG cleaning or replacement. Here's a link for that one:
"Check-engine light: Drivability problems accompanied by check-engine light often due to EGR exhaust passages clogged. (1999-2001)" :
http://consumerguideauto.howstuffworks.com/1999-to-2003-mazda-protege-2.htm
While trying to see just where the ERG valve sits in my Mazda, I came up with an even easier fix:
Looks like the forum's "Insert Image" feature doesn't like it when the characters "IMG" are in the url, so I'll just include the actual link:
http://cid-0ba9610cbd3ba347.skydrive.live.com/self.aspx/Protege 2002/IMG^_6942B.jpg
Here's a longer view pic:
http://cid-0ba9610cbd3ba347.skydrive.live.com/self.aspx/Protege 2002/IMG^_6941B.jpg
Yep, that's solid aluminum duct tape applied in overlapping bands to a broken fresh air intake hose. I cleaned off the plastic pretty good with a damp cloth straddled around the hose first. I cut ~18" lengths of the tape (don't remember exact length, but they were ~2" longer the circumference of the duct.
Honestly, I have 1986 and 1993 Fords, and their plastic air intake hoses never cracked in half just sitting there. If you're reading this Mazda, please take note of this.
Btw, don't forget to pull off the negative battery terminal for a couple minutes to reset that light (I guessed at 10 minutes).
Btw, changing the air filter will put some stress on that aluminum tape. Check the tape after a filter change.
Hope this helps someone.
Regards,
Brcobrem
Regards,
Brcobrem
