Blake_peanut: True TBE with high flow downpipe will produce about 2 more pounds of boost under load, especially if you are catless. Even with cats, you'll probably see more boost under WOT in the higher gears. Do you have a boost gauge and is that what you are seeing?
If your boost is above stock level, that's reason to go one step colder, IMHO. With your mods you should be about 40 whp above stock (maybe a few ponies less if you have cats). This is right at the border line for one step colder plugs. Could probably go either way.
Some might say stay with stock heat range. All I can say is that my mods are much like yours except that I am sticking with the stock BPV because it does not leak. I went one step colder and it seems to be working well for me. I'm getting some extra protection against detonation and not fouling, even after putting more than 10,000 miles on the new plugs.
Check my sig for mods and for the plugs I run. NGK's do have to be regapped down to .030 (the gap comes way too big) but all plugs should be checked and adjusted anyway. No biggie. Just get the wire gauge/gapping tool. It's cheap.
If you have a stop watch, time your 60-100 mph runs before and after changing plugs. I think you'll hold timing advance a bit better when you romp it and see a little performance gain with one step colder plugs.
