mazdaspeed32007
- Mazdaspeed3
i was running the accessport v103 fmic map and my ecu threw a U2064 code which is, off the top of my head, a multiple malfunction code error. asked around no one really knew what it meant and it was concluded it wasnt serious.
along with the u2064 code recently my car wouldnt start and it threw a u0101 and u0100 code which are specific parts of the integrated circuit. this caused a malfunction in the way my ecu talked to the car. basically u0100 and u0101 are certain parts in my ecu that arent working correctly and it causes a communitcation error with the pcm not allowing my car to start for some reason. this happens randomly and in the past 4/5 days it just wont start. im not sure whats going on here but i think cobb needs to chime in on this thread because i have a car that wont start. i need some guidance on what i should do. i reverted back to the stock map and it did nothing. im afraid the malfunction cause a permenant glitch in the ecu and if this is true im dead in the water on how to fix this problem.
