twodaystoofar
- 2003 Mazdaspeed Protege
Is the head on a MSP and a 626 the same? Also is the cam positioning sensor the same? I did a engine swap and it keeps flooding Trying to narrow down what it may be....
same here
the 626 heads that dont have a distributor are the same...but i did a 626 engine too and mine still wont run..i actually got it to start but it wont run or do anything under 3k rpms..i think my MAF is fried tho...
but i did notice a lot of fuel in cylinder one...i had to blow it out. will urs even run?
Is the car throwing any codes?
It will crank like it wants to start but wont run. Kind of like when you have bad plugs, but when i pull the plugs out they are soaked in fuel.exactly what does it do?
damn same here. it will fire like once then stop. i dont have any codes either. im still holding out that its the MAF in my case
idk but changing the motor wont have anything to do with the ecu...
lol dude the "reflash" is the same for every msp through mazda....and if you have a ssafc or whatever that doesnt even affect idle! or anything at lower rpms
