And that was only the rear right? No modifications to the front?
You only need to run a spacer bc the center bore of the wheel is too small. Have them bored out some and you don't need a spacer (but then they don't sit as pretty lol) 3mm spacer makes the wheel sit flush. Without it due to the center bore the wheel will wobble. I ran a 5mm in the front bc I had it already, and aesthetics. I run a 215 to get a slight stretch to help with rubbing in the rear. Getting your fenders rolled would solve rubbing issues. I'm looking into running 225's or 245's this summer.
