How To: 2.0 Header Installation
me and a buddy are going to attempt to intall my header in about a week... read almost all the pages but got tired of reading... any thing i should consider before the frustration begins? p.s. I've placed an order for a new mani gasket and donut gasket..
PB BLaster.......if you don't use it i ain't helpin! lol
Hit the nuts and bolts under the car where the stock header/jpipe meet the midpipe
then hit all the nuts on top where the manifold hits the block
Do as often as possible!! Just don't do it while the motor is hot!!
And trust me, i can handle a header swap. I've gone from stock to obx to stock to obx to stock to ractive to stock to ractive to stock to ractive to stock
That many times, yes. Had to go back to stock for the car to go in for warranty work
So, between me and John, this should be a cake walk, AS LONG AS YOU PB BLASTER THAT PIG!!!
changed out my header today and it feels greeeeeat. pretty easy to do but sliced my thumb open with a knife haha so know i have a splint and a nail cut all the way through to the bed but regardless i stuck it through to get my header done then went to a care center to get a tetnaus shot.
Guy on TMF says you can still order another EGR threaded bung to put back in the header just incase you need to put the stock one back in
if it doesn't thread back in easily almost by hand, i would replace it and not force it
i tried to feel around the egr valve and it seemed to have no end lol but if that is what's causing to throw my cel then ill get a replacement andwhen we meet we can see about the install. also one of my sensors is off so when i get the midpipe ill get a new slot drilled and threaded to install so in the meantime i'm gonna pick up some extensions
Is that stuff flammable? dont want to drive to soon after using it ;)
Ya, waiting wouldn't do any good anways. It doesn't evaporate so it would still be there to burn no matter how long you waited.
Ken, you mentioned that removing the airbox/resonator doesn't hurt the performance. Would you say the car would run better with it on or off? I'm thinking about taking mine off but really want to know if it will be worth it.
Honestly, it doesn't make any kind of difference. You won't even be able to tell whether its on or off. Its just a piece of plastic.
+1 The air flow isn't really interrupted by that piece. Altering your grille to get a little more air flow into the "ram-air" inlet is the only thing that *may* improve the stock setup. Still won't be anything noticeable tho.
