APutvinskiMP5
zoom-zoom
- 2003 Mazda Protege5
liquid wrench is my new best friend, it finally did the trick, thanks guys
does anyone have any tips for removing the spring loaded bolts?
hey i went to go get the header, its gone? No more on protegegarage.com?
Guy on TMF says you can still order another EGR threaded bung to put back in the header just incase you need to put the stock one back in
PB BLaster.......if you don't use it i ain't helpin! lol
Hit the nuts and bolts under the car where the stock header/jpipe meet the midpipe
then hit all the nuts on top where the manifold hits the block
Do as often as possible!! Just don't do it while the motor is hot!!
And trust me, i can handle a header swap. I've gone from stock to obx to stock to obx to stock to ractive to stock to ractive to stock to ractive to stock
That many times, yes. Had to go back to stock for the car to go in for warranty work
So, between me and John, this should be a cake walk, AS LONG AS YOU PB BLASTER THAT PIG!!!
Is that stuff flammable? dont want to drive to soon after using it![]()
Ken, you mentioned that removing the airbox/resonator doesn't hurt the performance. Would you say the car would run better with it on or off? I'm thinking about taking mine off but really want to know if it will be worth it.
Honestly, it doesn't make any kind of difference. You won't even be able to tell whether its on or off. Its just a piece of plastic.
