Hey SGT, if you dont mind me asking. What offset and width are your wheels? I got a set of the 20's that I tried on my 5 ( in this thread )but I got them in 19's instead because the offset was 3mm higher than the 20's and I thought I might be able to stretch a 215/35 tire over it for clearance purposes...I'd like to go with the tire you have but  the rim pokes slightly past the fender and I'm thinking if I dont get an angle on the tire its going to hit the fender......any help would be great...I sent Tillyspeed a PM asking about his but he never got back to me....but I havent seen him on lately....Then I noticed you where running 19's too.
Kid5, no problem, happy to help....
I'll try to keep this as short as possible, if still confused PM me.
1.  My after market rim and tire guy said this:
a) 225/35 R 19 is the MAX he'd go with for Three reasons:
b) Yes the Rim WILL "the rim pokes slightly past the fender" past or AKA stick out from the fender, this is NOT A PROBLEM, because of the way the suspension works on the 5, tire goes "into" the fender at an angle.
c) You CAN go 235/30 R 20, but that is such an expensive Rims and Tires, BOTH special order here in Okinawa, it'd take a $3,000 purchase up to (are you sitting down?) $6,500.00 deal, ONE FREAKING INCH???  (shocked)  Well I guess the 20" crowd is the "shizzle Nizzle" arou nd here and rule of thum, SUPPLY AND DEMAND, a few years ago, I did 17" AND when you needed to buy new tires in 3-4 years, (If lucky to go that long) it's going to cost ya $1,800 JUST FOR THE TIRES! (upbum)
2.  "What offset and width are your wheels?" -20 I think, I did not check, I just said to him, "make em fit" and he did all the math, if you PM me, I can ask him next time down there at the store.  If you got to a REAL tire dealer, that is part of the 1,000's of dolers you are spending, LET THEM DO THE MATH and BAKC IT UP!
3.  "19's instead because the offset was 3mm higher than the 20's and I thought I might be able to stretch a 215/35 tire over it for clearance purposes..."
Not a problem, I run 225/35 R19's not a problem.
Hope that helps, but really I leave the MATH to the pros, that is what they get paid for.
Peace!(rei)
