Nliiitend1
What's the hub bore size? It has to be at least 67.1 mm to fit over the MS3's hubs (assuming it hasn't changed since the 1st gen - which it likely hasn't). If it's smaller, it would have to be machined to a larger size...
Sorry i was wrong, i was looking at the protegespeed specs lol
Actually, the 2010 has 12.6 on the fronts. the rear is smaller, but i dont recall the exact size.
The spec sheets I've seen show that they're the same sizes:
Front: 12.6" (320 mm)
Rear: 11" (280 mm)
i was going to go down to 7 inch wide wheels. Guess if i do that i better get an offset REALLY close to 52.
