it is round and has a pattern in it. like a backwards 3 and a 3 inside if u can m,ake sense of that... so how to do this.
just bought some night shade... can someone tell me how to take off the side lights on the front fenders and the reflectors on the sides of the front bumber?
The side lights just slide off. Pull them to one side and pop them out. What reflectors are you talking about? The ones in the headlight?
how exactly do i pop them out? i can get them to slide to one side a bit... but then if i were to pull away from the car it feels like theyre gonna break.. is there a certain way ?
Here's a queston, on the P5 when you turn on the brights, should the low beams stay on? On my car they do... They did with the stock H7's and with my HID kit they do as well... So, is that normal?
just a thot, would it be a good idea to aim the headlights lower and drive with the high beams on as well to produce more light while driving @ night?
Still working on my cluster.Started last tuesday on and off doing it right alot of sanding just to get it right not even close to being done. Also washed and waxed the GF's car.
Yup, that's normal.
Also, if you "flash" your brights while the headlights are off, it DOES fire the HID's each time you pull the high beam stalk
Did you test fit it yet?
From what it looks like it might block of some of your warning lights. (seat belt, maybe even the CEL.
I did one that that. (only one side though.lol)
lol yea only part of it but I really don't care and no cel's :) And it's not even that bad here's before the bondo work.Can't go to much lower on the cut because of the tab that hold's the guage surround on.
