fishdonotbounce
Registered Zombie
- 08.5 CWP Speed3
Thanks a lot.
As far as lowering goes, I really don't mind the stock height, bu I do intend to lower it eventually. I either want to get something subtle like the Racing Beat springs or the Eibach Pro-Kit.
BTW, anyone know how to remove the interior fog switch?
No problem. The fog switch is really easy. if you open your door and look on the side of the dash there, that panel pops off very easily. You can start it with a flathead and it'll pop right out. Then you can put your hand in there and depress the top and bottom of the switch and push it out. I just had to do it when I was wiring my gauges.
