Went to take my car through an emissions check today and failed. I had 5 monitors that were not set, including the catalytic converter, O2 sensors, and others I cannot recall right now. A guy there told me it was typical to see if the battery had lost power, and the ECU had lost power. Battery has not lost power at all since January, when I replaced the battery. I have a Haltech F10X that did have to clear a CEL that came up a few days back. I believe it was Friday or Saturday, can't remember exactly. My assumption is the piggyback clears the stock ECU memory (including these monitors) on the next startup when there is a CEL present, or does it do it on every startup??
Also, is there an option in the software to disable this memory reset so that I can drive the car enough to re-establish the monitors?
How long do you have to drive before these monitors get set anyway?
