Can't decide which Header to get
oh, and one other gain, check this!
It's enough that you'll need to reaim your headlights!
(boom01)
Damnn....The Ractive 4-1 header weighs 16.2lbs lighter than the stocker.....So you get a combo of power and weight reduction......lol
well def. catch up in less then a week so i can get the header off your hands lol but for now i have to get to work laterzz
Sounds good man! I'll hold it for ya.
PM coming your way with my number.
so the header is basically out of the way... lol what full exhaust do you all suggest to get because i need to get them both done simulaneously? don't hold out
And what about that guys mp3 ecu were you saying earlier that it was for sell or if not where can i get one?
if you're up for it, and can hit up your bolts on the midpipe and header with PB blaster, i can do the header swap if you like.
As to exhaust, i recommend going with a racing beat catback, as well as a high flow midpipe.
I think protege garage sells a high flow catted midpipe in 2.5" as well as the Racing Beat exhaust
If your staying basic bolt on NA powered, 2.5" exhaust should be MORE than enough. 3" and you'll just fizzle out
If you have the HKS is it a cat-back or axle-back? Cat-back is better, and if you don't have a cat-back. get custom piping done. 2.5" all the way to the Header
You can get in contact with him here and send him a PM. This is his thread! Actually his name is SpicyOrangeMSP
http://www.mazdas247.com/forum/showthread.php?t=123746537
Spicy is figuring out if the ecu will work out but there is another guy on the forum that has a Fsze motor and he's asking the same question.
And protege garage has a catback? because i saw the full exhaust for 450 and wondering he it will be cheaper. p.s. i'm on mobile internet
a cat back is a full exhaust. you might be confused. i think your thinking of the axleback portion. that would be just the muffler and the pipe from the axleback. a catback is run from the 2nd cat all the way back to the car. so yes it would be 450 for the cat back. if they do sell just the axleback portion im not sure what that runs cost wise.
