You are correct. I had no other way to route my IC piping due to the length of my radiator (Not able to route through SMIC location), and b/c i originally had the pipe going under the frame in which you could see badly! With the one half of the intake at regular length it rubbed my IC piping and stock overflow, my weapon r resevoir is just below the intake. I'm going to move it over into the empty location though as I do not like it hanging that low.
Having the resevoir that low, would it cause to lose more coolant than normal by chance?
Seems after replacing water pump and timing belt, i had a loss of coolant when i checked it last night. I'm thinking i may have a leak in rad or rad hoses.
