...with stock airbox we're running more rich how much leaner we would run putting ram/cai?
The engine wouldn't run leaner at all.
This isn't 1982.
it's not about 82 it's about the way calculations are done.
carburetor guru lol
right right. it is not like putting extra it's just (absolute) putting more...I think what he was saying is that all intake air, ram or otherwise, is still metered by the MAFS. Even if the ram air setup did net a positive difference in mass air flow through the intake, the ECU is calculating fuel delivery based on the increased airflow.
VTA on a MAF engine will make an already pig rich situation worse on this engine.
doing a VTA without tuning out the extra air from the BOV, 50/50 or 100%, is making a pig rich engine worse.
Always makes me laugh when people have there BOV set to VTA that aren't running a tuned setup.
Their response is "I like the way it sounds".
Idiots.
My respons is " I like how well it holds boost". I understand that if i am running vta I might run into problems but 50/50 is treating me just fine. And my DH shows me not to be concerned.
Nope. None of that concern me. I know I should listen to you because you do know alot. But like I said my car is running just fine. Better than when it had the stock bov, so how is 50/50 making it worse. If I was racing where I would go WOT and all, then yes i'll switch to reci just to be safe.
