hi guys - first post
i'll be getting into a '10 MS3 monday and already started thinking about suspension and rims. I'll probably go with coilovers with some wide rims with a low offset
What's a "safe" aggressive fitament? By safe meaning, I don't mind running some camber (not more than -3), cutting some fender liners, and some rolling.
I'm thinking of doing 9"-9.5" with a 30ish offset
Why ruin a perfectly good suspension stock. Why not drive it first and see if you need a better suspension. The stock limits are quite high for the MS3. If you are lowering and putting overly fat tires on for looks only, then your lost and have been swallowed up by the wider is better ignorance.
