Protege Garage Turbo Inlet Installed
In my case, I could've been getting leaking around the turbo inlet clamp. To be honest, I only gave it a few runs and pulled it back in the garage. After that, I decided to clean my MAF and reset the ECU, so I'll report back in another 100 miles or so. Maybe I'll have a different opinion. But one opinion won't change... that is a very nice piece for the price, Ken!
Installed mine today. I do get a smoother launch from first gear. Will reset the ecu again and give it a proper test drive tomorrow. So far so good. Thanks Ken you guys made a good product. Here are some pics.
Hello turbo
PG Turbo Inlet
one more
Now I can't wait for my CP-e nano SRI to get here.
P.P.S. - Ken - that vac hose could be about 1/2" longer. Mine was a pretty tight reach.
Really, vac hose fitted just fine with mine. Maybe it was how you install the inlet. I slid the inlet into the coupler straight in until I can feel the tip of the inlet touch the turbo then I rotated the inlet counter clockwise as further down and that gave me a perfect fit. Anyways good to hear you like the TIP.
PG Turbo Inlet
How is the turbo inlet with the stock intake?
What do you mean? I decided to install the TIP since I got that first than the SRI. The picture is not showing the whole connection between TIP and the stock air box but it connects just like the stock inlet. Nothing different was done.
He means the performance/sound?
Oh my bad. Yes you will notice some performance because, the stock inlet is as restricted as the stock air box. That's why we recommend replacing the stock inlet if you're doing an after market intake. There is no sound coming from the PG TIP with just the stock intake. But like some people say I have to drive more so that the ecu can do some adjustments and I should get that ready to go feel. Everything PG claims it to do on their web site, it does it. I'm a believer.
ohhh go easy on it! eeek! is it ok that I would do random fast accelerations?!?! other than that I drive normal..
I wish they had a dyno nearby where I live, the closet one is in south dakota!!!!! I jsut want to know how much my little engine is pushing out! any guesstimates?!?!
any update on order #8510?
if it is possible i would like to change the shipping address. i didnt realize this would take so long to ship.
Not the right place for this post. Please pm myself or captain KRM for updates.
I will look into this order for you.
just installed the pg inlet like 20 min ago and was not expecting that much from it but i was very wrong :) the car runs so much smoother im runnin a turbosmart dual port with a aem cold air and it just made the dual port sound like sex its more of a woooosh now all in intall was straight forward took me like 45 min all in all 10 of 10 for simplicity and sound and thanks ken for the part
oh ok.. and thats to the wheel? what kind of TMIC do you have? how do you think it is to the crank?
ETS 3.25. And crank HP is nothing unless you can get it to the ground. so yea.. WHP on a mustang dyno..so theres some loss on it for numbers but it is the most realistic on what your putting down.
